    Results 1 to 6 of 6
    Thread: Power steering
      Power steering
      Just installed a new harmonic balancer on my 99 A4 corvette.Rack must come out to do this after putting back in I now have no power steering at idle OK when rpms are up or while driving.
      Jul 2002
      Mesquite, TX
      Bled the system?
      Any tricks no luck so far keeps showing active handle warming up
      I think the procedure for bleeding the system is to raise the front wheels off the ground, have the engine running, and slowly move the steering wheel from rack to rack. This forces fluid through the system and the power steering fluid reservoir should act as a bubble trap. Keep an eye on the resevoir as you do this, if the level comes down you did in fact have air in the system. Top the fluid level off and you should be good to go.
      Good luck!
      Paul
      tryed that works great execpt at idle
      Nov 2004
      Colorado
      Theres a pressure sensor on the C5 rack, check and see if its plugged in
