    Results 1 to 4 of 4
      Jun 2008
      marin county California
      wilwood and 69 camaro backspacing?
      Anyone have a 69 camaro with 18x8 245/40r18 up front with wilwood disc brakes? I know when convertering to Wilwood Disc Brakes they sit .18 or almost a 1/4" out further than the stock postions. I see some guys going with 5" of backspacing and some going 4.75" I have not called Baer brakes yet but would not mind to hear that info also. Thanks
      Aug 2003
      Orlando, FL
      100s of them, 4.75BS works perfect. make sure you have -1/2 degree Camber in the alighnment
      Jun 2008
      Thanks for that. I checked out your site. Are you also a part dealer? So , do you guys sell complete kits? Send me a PM if you do. I am wanting to convert my 69 camaro from a stock front disc and rear drum to a four wheel disc set-up. The 2 I am considering are Wilwood and Baer. I really like the Baer Track system. 13" front, 12" Has a price tag of about $2500. Thats the problem. I'ts a 2 piston up front and a 1 piston rear. I'm not sure if that really matters. I still need to get more info on Wilwood also. What would be the comparable kit from Wilwood? Baer also claims that the hubs are in the factory locations. They do not come out .18" like Wilwood. I'm sure there are pro's and cons to both brands. Like to hear any comments people have Thanks Will
      Aug 2003
      Orlando, FL
      Below is the information on our Total Car G Machine brake Packages. And for a limited time we are including the $200 Wilwood tandam Master Cylinder as a free upgrade in Polished or black E Coat.
      Prodigy Customs introduces our Total Car G-Machine Brake Packages for Camaro, Chevelle, Nova, F body, A body, G Body, Ford, Mustang, Mopar and many others featuring the worlds best brakes, Wilwood Disc Brakes! Prodigy Customs EXCLUSIVE Total Car G Machine Brake Packages takes all the guess work out of your 4 wheel disc brake conversion. Our kits include front and rear Wilwood brakes in the size of your choice, front sizes from 10.75" - 14" rotors for all popular applications, Rear brakes include INTERNAL E BRAKE in sizes from 12.2" to 14" for all popular applications. Calipers are available in Four Piston to Six Piston, Dynalite and Superlite Calipers Our exclusive Total Car G-Machine brake packages include everything required to convert you original brakes to monster 4 wheel disc. Call for your exact application.
      Kits include:
      Wilwood Parts Include:
      Front and Rear Wilwood Kits
      New front Hubs
      3 pints Wilwood DOT 4 high temp Brake Fluid
      Prodigy Customs Parts Include:
      Front Braided Brake Hoses
      Rear Braided Brake Hose
      E brake Cables for Internal E Brakes
      Master Cylinder
      Adjustable Proportioning Valve
      We even include Safety Wire and Safety Wire Pliers for proper 2 piece rotor assembly
      10.75 to 12.2"F / 12.2" R kit is $1850
      NOTE:
      ($1850 Kit includes BLACK CALIPERS and NON Drilled / Slotted Rotors)
      Upgrade cost are ac***ulative and are added to base kit price of $1850
      Upgrades include:
      (6) piston Dynapro front caliper upgrade (12.2" kits only) $400 option
      13" (6) piston Superlite front upgrade $900
      14" (6) piston Superlite front upgrade $1100
      13" (4) piston Superlite rear upgrade $900
      14" (4) piston Superlite rear upgrade $1100
      Drilled and Slotted Rotors are $200 Option
      Red, Blue, Yellow, Silver and Polished Calipers is $200 Option,
      Wilwood Aluminum Dual Reservoir Master Cylinder is $170 Option
      Wilwood Aluminum Dual Reservoir Master Cylinder (polished or Black E Coat) is $200 Option FREE for a limited time
      Dual Diaphram Polished Stainless Power Brake Booster $200
      Hydratech hydro booster (Deluxe kit with lines) $650 option
      Base Total Car G Machine Brake Package with 12.2" F (4) piston Dynalite / 12.2" R (4) piston Dynalite kit as shown with Upgrade:
      RED CALIPERS,
      DRILLED AND SLOTTED ROTORS,
      POWER BOOSTER
      AS SHOWN IS $2450.
      Extreme Total Car G Machine Brake Package with 14" F (6) piston Superlite / 14" R (4) piston Superlite kit as shown with Upgrade:
      BLUE CALIPERS,
      POLISHED WILWOOD MASTER
      AS SHOWN IS $4650.
      Custom pedal set NOT INCLUDED
