View Full Version : wilwood and 69 camaro backspacing?
will-ss-69
04-05-2009, 09:25 PM
Anyone have a 69 camaro with 18x8 245/40r18 up front with wilwood disc brakes? I know when convertering to Wilwood Disc Brakes they sit .18 or almost a 1/4" out further than the stock postions. I see some guys going with 5" of backspacing and some going 4.75" I have not called Baer brakes yet but would not mind to hear that info also. Thanks :cheers:
ProdigyCustoms
04-06-2009, 01:43 AM
100s of them, 4.75BS works perfect. make sure you have -1/2 degree Camber in the alighnment
will-ss-69
04-06-2009, 10:47 AM
Thanks for that. I checked out your site. Are you also a part dealer? So , do you guys sell complete kits? Send me a PM if you do. I am wanting to convert my 69 camaro from a stock front disc and rear drum to a four wheel disc set-up. The 2 I am considering are Wilwood and Baer. I really like the Baer Track system. 13" front, 12" Has a price tag of about $2500. Thats the problem. I'ts a 2 piston up front and a 1 piston rear. I'm not sure if that really matters. I still need to get more info on Wilwood also. What would be the comparable kit from Wilwood? Baer also claims that the hubs are in the factory locations. They do not come out .18" like Wilwood. I'm sure there are pro's and cons to both brands. Like to hear any comments people have Thanks Will:smoke:
ProdigyCustoms
04-06-2009, 11:42 AM
Below is the information on our Total Car G Machine brake Packages. And for a limited time we are including the $200 Wilwood tandam Master Cylinder as a free upgrade in Polished or black E Coat.
Prodigy Customs introduces our Total Car G-Machine Brake Packages for Camaro, Chevelle, Nova, F body, A body, G Body, Ford, Mustang, Mopar and many others featuring the worlds best brakes, Wilwood Disc Brakes! Prodigy Customs EXCLUSIVE Total Car G Machine Brake Packages takes all the guess work out of your 4 wheel disc brake conversion. Our kits include front and rear Wilwood brakes in the size of your choice, front sizes from 10.75" - 14" rotors for all popular applications, Rear brakes include INTERNAL E BRAKE in sizes from 12.2" to 14" for all popular applications. Calipers are available in Four Piston to Six Piston, Dynalite and Superlite Calipers Our exclusive Total Car G-Machine brake packages include everything required to convert you original brakes to monster 4 wheel disc. Call for your exact application.
Kits include:
Wilwood Parts Include:
Front and Rear Wilwood Kits
New front Hubs
3 pints Wilwood DOT 4 high temp Brake Fluid
Prodigy Customs Parts Include:
Front Braided Brake Hoses
Rear Braided Brake Hose
E brake Cables for Internal E Brakes
Master Cylinder
Adjustable Proportioning Valve
We even include Safety Wire and Safety Wire Pliers for proper 2 piece rotor assembly
10.75 to 12.2"F / 12.2" R kit is $1850
NOTE:
($1850 Kit includes BLACK CALIPERS and NON Drilled / Slotted Rotors)
Upgrade cost are ac***ulative and are added to base kit price of $1850
Upgrades include:
(6) piston Dynapro front caliper upgrade (12.2" kits only) $400 option
13" (6) piston Superlite front upgrade $900
14" (6) piston Superlite front upgrade $1100
13" (4) piston Superlite rear upgrade $900
14" (4) piston Superlite rear upgrade $1100
Drilled and Slotted Rotors are $200 Option
Red, Blue, Yellow, Silver and Polished Calipers is $200 Option,
Wilwood Aluminum Dual Reservoir Master Cylinder is $170 Option
Wilwood Aluminum Dual Reservoir Master Cylinder (polished or Black E Coat) is $200 Option FREE for a limited time
Dual Diaphram Polished Stainless Power Brake Booster $200
Hydratech hydro booster (Deluxe kit with lines) $650 option
Base Total Car G Machine Brake Package with 12.2" F (4) piston Dynalite / 12.2" R (4) piston Dynalite kit as shown with Upgrade:
RED CALIPERS,
DRILLED AND SLOTTED ROTORS,
POWER BOOSTER
AS SHOWN IS $2450.
Extreme Total Car G Machine Brake Package with 14" F (6) piston Superlite / 14" R (4) piston Superlite kit as shown with Upgrade:
BLUE CALIPERS,
POLISHED WILWOOD MASTER
AS SHOWN IS $4650.
Custom pedal set NOT INCLUDED
