    Results 1 to 6 of 6
      May 2002
      Southeastern WI
      Plastic PS reservoir
      I have a power steering pump like the one pictured. I want to connect my braided DSE return line to it but must first remove the 90* plastic fitting. Does anyone know how to remove it? I am afraid of cracking the reservoir.
      Jeff
      Ortonville, Michigan
      The fitting is part of the reservoir. If you want to remove it to put in a -AN fitting just use a saw or cut off wheel to remove the 90 degree part leaving the round lug behind it in place. Then just drill and tap for 1/4 pipe or an O-ring fitting. Hope this helps.
      Billy Utley
      May 2002
      Southeastern WI
      Exactly what I was looking for. Thanks!
      Jeff
      May 2002
      Southeastern WI
      And when I f it up because I can't read instructions and cut the whole thing off does anyone sell just the reservoir separately? DSE only seems to have it with the pump.
      Jeff
      Aug 2006
      Belforest, AL
      Yikes.
      Maybe you could try Weld-On # 4052 (plastic adhesive) and attach a plastic nut?
      Weld-On actually melts the plastic and fuses it. Its not really a simple glue.
      Todd S.
      "I like to race school buses..."
      Kingsport, TN. 30 min. from Bristol and 90 min. from Pigeon Forge, TN.
      I don't think you'll mess it up. Just be carefull to use the proper drill size and tap.
      You can buy just the reservoir. I forgot where I've seen it but it is available.
