View Full Version : Plastic PS reservoir
Van B
04-05-2009, 07:11 PM
I have a power steering pump like the one pictured. I want to connect my braided DSE return line to it but must first remove the 90* plastic fitting. Does anyone know how to remove it? I am afraid of cracking the reservoir.
72novadriver
04-05-2009, 09:43 PM
The fitting is part of the reservoir. If you want to remove it to put in a -AN fitting just use a saw or cut off wheel to remove the 90 degree part leaving the round lug behind it in place. Then just drill and tap for 1/4 pipe or an O-ring fitting. Hope this helps.
Van B
04-06-2009, 06:52 AM
Exactly what I was looking for. Thanks!
Van B
04-06-2009, 08:47 PM
And when I f it up because I can't read instructions and cut the whole thing off does anyone sell just the reservoir separately? DSE only seems to have it with the pump.
LateNight72
04-06-2009, 09:57 PM
Yikes.
Maybe you could try Weld-On # 4052 (plastic adhesive) and attach a plastic nut?
Weld-On actually melts the plastic and fuses it. Its not really a simple glue.
jpdeuce
04-08-2009, 03:49 AM
I don't think you'll mess it up. Just be carefull to use the proper drill size and tap.
You can buy just the reservoir. I forgot where I've seen it but it is available.
