Results 1 to 12 of 12
Thread: Closeout panels for minitub??
03-14-2005 #1
I got my passenger side floor cut for the minitub, now I have a question about the closeout panels for the shock tower. The DSE instructions seem a little vague and the video doesn't really show this as clear as I would like.
In these pics, it looks like a 3/4 inch flange was bent down and not much of the original metal inside the tower was removed: http://www.detroitspeed.com/ThompsonPage0110.html
http://www.detroitspeed.com/ScottsPage10.html
In this pic, using the current DSE instructions, it looks like the shock tower was gutted, the closeouts became the flange, and the floor was actually cut 2.75" inboard and no flange was left: http://www.superchevy-web.com/tech/0409sc_minitub/
So, where I'm getting confused is where the DSE instructions say that the actual cut line is 3/4" outboard of a line drawn 2.75" inboard of the original mounting surface of the inner housing. If I understand correctly, the actual cuts on the shock tower need to be 2.75" inboard and that area, along with the section of frame that is cut out, will not have a 3/4" flange to bend down, thus the frame closeouts will also become the flange that the Deep Tub is welded to. Is that correct?
Nathan1969 Camaro - 355 sbc, TKO 600, 12 bolt, Global West suspension
