    Results 1 to 8 of 8
      Sep 2008
      Kathleen, GA
      brake fitting adapters ?
      anyone know where to get brake fitting adapters ? I need female SAE to metirc male 10mm x 1mm and SAE to 11mm x 1.5mm fittings.thanx
      Oct 2005
      Orlando, Fl
      NAPA usually carries quite a bit of fittings.
      Michael Barnes
      71 Chevelle - LS1/T56 swap - On the Street!!
      Auburn, WA
      Or try Williams Oil Filter Service in Tacoma, WA. They carry just about every oddball fitting you can imagine.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Sep 2008
      Kathleen, GA
      Quote Originally Posted by silver69camaro View Post
      kind of a drive for me
      Auburn, WA
      Quote Originally Posted by LSXfan View Post
      That's what USPS is for.
      Matt Jones
      Mechanical Engineer
      Oregon
      Most auto parts stores stock one brand of fittings, whether it be Edelmann, Everco, or Weatherhead, all of which should have the fittings that you're looking for.
      3/8-24 SAE female X M10x1.0 ISO bubble: Edelmann #271300, Everco #3024B, WH #1442
      3/8-24 SAE female X M11x1.5 ISO bubble: Edelmann #264000, Everco #3030, WH #7973
      If you're having trouble with your local auto parts stores, you may give Brakequip a call as I believe they have those fittings as well, just with their own part numbers.
      Tobin
      KORE3
      It's what I does.
      Sep 2008
      Kathleen, GA
      thanx for the info !
      Sep 2008
      Kathleen, GA
      local NAPA had both part numbers on the shelf ! thanx for the help !!!!!
