    Results 1 to 3 of 3
      Oct 2007
      ridgefield ct
      would moving the rear UCA mounts screw things up?
      one of the very few (mounting) differences between a 95 caprice rear and a g-body rear is that the UCA mounts sit forward of the diff center instead of centerline. will shortening the UCA's cause handling issues? (they are at the same angle and plane) i do plan on using johnny joints in the UCA and LCA's to eliminate the usual bind issues, if that matters.
      thanks
      nick
      work in progress--for the next 10 years.
      1987 monte carlo ss 383ci, 9.7:1, xe274 cam, vortec heads, 200r4, 3.73 posi.
      Oct 2007
      ridgefield ct
      anyone????
      Jan 2009
      Fort lauderdale
      it shouldnt do anything noticeable. just have to start watching the pinion angle. it will change more with suspension movement
