View Full Version : best st. pump with Hydroboost
ss dave
03-25-2009, 12:15 PM
Used several pumps now and still have a whine, even after bleed the bubbles.
Have a Hydratech hydroboost and a Saginaw with remote resevoir.
Can someone suggest a pump that works and puts out 3.0gpm .
ss dave
03-25-2009, 01:47 PM
OK did a little more footwork.
Called AGR and talked with Larry, very helpful.
Got a 1250psi 3-3.5 gpm TC pump coming.
Called Vanco Power Brake Supply, talked with Van, a lot of help and useful info. Vanco does alot of hydroboost stuff, apparently helped Ford with their hydroboost problems.
Van will look at my set-up and see if any problems with install.
MuscleRodz
03-25-2009, 03:37 PM
How big is your reservoir how how are the return lines done? Is the box on the tee side or is the hydroboost?
thedodgeboys
03-25-2009, 04:46 PM
I agree most people that have had a noise in the pump went to a pump-mounted reservoir
Also the reservoir needs at least a ¾ inch feed line and no longer than 18 inches long.
