Results 1 to 16 of 16
03-20-2009 #1
- Join Date
- Feb 2009
- Location
- In the woods...
- Posts
- 26
When do you NEED to upgrade your brakes - 2nd gen F-body
What was the deciding factor that made you folks decide to upgrade your stopping power - other than the fact that drums/small rotors look out of place behind larger open rims?
I can't argue with Newton --- F=ma. My car weighs about the same, but my acceleration is much faster than stock (I probably have a mid 12 second car). Thus, I would assume there comes a point where I need more stopping force. I currently have the original power disc/drum setup to stop my 3600 lbs f-body.
Is there a threshold you cross that dictates that it is time to upgrade the braking system?
I appreciate your thoughts/insights... I hope I posted this in the right spot - mods please me help otherwise!
Eric
03-20-2009 #2Any time you are upgrading the vehicle's wheels to be a larger diameter than came from the factory, you are increasing the demand on the brakes. Any huge increase in vehicle power will also put strains on the stock system. You need to take consider your personal driving habits as well. How far do you intend to push the car?
On my Firebird it was an easy call to make regarding the brake system as the car came to me with the stock four wheel drum brake setup. I think reading Steve Chryssos' post at the link below only helped to solidify my decision to upgrade.
https://www.pro-touring.com/forum/sh...ad.php?t=13892
03-20-2009 #3
