    Results 1 to 2 of 2
      Jun 2006
      Halden, Norway, Europe
      Excellent source for bushings!
      Hi,
      let me start by saying I don't work for this company or is related to it in any other way, just wanted to share a good site with you guys.
      I stubled across this site while searching for rear end bushings for my 64 Chevelle which is the only year chevelle to use a smaller axle housing bushing.
      http://www.southwestspeed.com/index....Arm%20Bushings
      They have a huge selection of bushings in 3 different types, stock rubber, nylon-on-steel and steel-on-steel. The ones listed are for LCA's and UCA's but I found out the bushings I needed was the same as a later model chevelle front (front)LCA bushing.
      I ordered the nylon ones, it should not bind like the poly ones, doesn't flex like rubber and doesn't need lube.
      Oct 2007
      Newark DE
      Thanks for the link.
