Results 1 to 7 of 7
03-11-2005 #1
Boyds boys doesn't know about painting.
I was watching an episode ( can't remember which car) Where the paint crew was saying orange peal was acceptable. I have learned from a good friend who is a professional painter. While some orange peal is normal but not the whole car. It doesn't seem like they are too knowledgeable in painting. I know that the proper technic can eliminate orange peal.
Tim
89 Lincoln Towncar pro touring project ( new info found for handling)
95 Explorer XLT OFF-Roader
95 Chevy Suburban LT 4X4
07 Harley XL1200L Low 08 Harley XL1200N nightster
Would you vote for someone who doesn't stand up for the flag?
03-11-2005 #2
- Join Date
- Mar 2005
- Posts
- 168
I dont think there are very many people who can paint bc/cc without getting some orange peel. Some...but not many.
03-11-2005 #3No matter what you will usually have to wet sand the clear to get a little orange peel out. Not a big deal as long as its all removed.
Adam_______Offical Car Name "ILLUSION"
383 Stroker, Stock cast heads, T-56 tranny, 4.11 gears, 2002 T/A dash, 4th gen interior including seatbelts, power lumbar seats, 18" Budnik Wheels, Hydraboost, QA1 shocks, DC Controller, Power steering conversion, fuel cell, unique exhaust set up........
ILLUSION Website-----------Old Website--------------My Car on Lateral-g.net----------- Need something designed?-AdFabDesign
03-11-2005 #4
Full Blown G-Machiner
- Join Date
- Nov 2004
- Location
- Roanoke, VA
- Posts
- 515
As others have said orange peel is normal on just about any paint job but you dont see it that often because a normal part of the painting process is wet sanding and buffing to remove it. When I was in the body shop business there is only one job that I can recall that came out "slick" and didnt require wet sanding and buffing.
GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
#614 11.9 @ 113
New stuff finished 08/06:
4L80E trans w/TCI PCM
Front: J&S UCA/LCA, QA1 coil overs
Rear: Caltracks/Belltech drop leaves
Empire drive line alum drive shaft
Polished 17x9 F/17x11 R ZR1s with 275s/315s
Syclone
Tow rig
03-11-2005 #5
- Join Date
- Mar 2005
- Posts
- 168
I have seen guys that can do paint jobs that and come out perfect, but they can pretty much command what ever price they want, and they do!! I have found that by using a short throw (3/32") da with a soft pad and paper with the holes, you can do 3/4 of the wet sand job with it and save LOTS of time and headaches. Wet sanding sucks!! One of the biggest benifits is that you are doing it dry and can actually see how much more sanding it needs without even stopping, the dust fills the small orange peel dimples, you just sand til its smooth and cant see the dimples anymore. After painting, I use the da and can usually da it, and have it buffed out in an afternoon. Of corse ther are spots you cant do with a da, but not many (mostly edges).
03-11-2005 #6
- Join Date
- Nov 2004
- Location
- NW Arkansas
- Posts
- 1,742
The paint jobs on the high dollar cars built by the top builders have a lot of orange peel! They guys that spray troy's cars will spray the car very dry because fat ladys ass is hard to cut out! Dry orange peel will cut out flatter than wet orange peel! there is no such thing as a paint job that does not need to be cut and buffed (they all have fat ladys ass or orange peel)
KENNY DAVIS HOTRODS
03-11-2005 #7
Banned
- Join Date
- Nov 2003
- Location
- Maine
- Posts
- 1,076
travis
exactly, no one out there will have an orange peel free finish, some are damn close, and my sata sprays as flat as any of them, but it also has alot to do with air flow, temp, and clear being used, as much as it is applying it, i would watch the dry sanding, it works but very easy to heat clear p and burn thru, wet with a soft pad and some 1500 works awesome, you do need to squeegee it to see what neds more attention, but once you do it, i can feel when it is there, and if it needs more
jake
