Results 1 to 16 of 16
03-10-2005 #1
Problems fitting 17" wheels with C5/Hybrid brakes
Anyone else run into this problem? I have the TC hybrid kit, and while trying to get some wheels, it seems there isn't room for the brakes. If this is so- then why do I keep seeing 17" TTIIs (of 4.75 and 5.5" BS) on so many cars?????
I'm working with Howard at Newstalgia to get some Billet Specialties Rebels & we ran into this problem while trying to go with a 17x9.5 (5.5 BS) for the front. Anyone run something similar? I've looked at the wheel chart, and things don't add up.
PLEASE POST PICS & SPECS OF YOUR SETUP (17" sizes); ANYTHING FROM 7" WIDE TO WHATEVER.
03-10-2005 #2
- Join Date
- Nov 2002
- Location
- Georgetown,TX
- Posts
- 2,557
When I sold a Baer GT kit to Herb Lumpp for his 66 El Camino,he had to change from 17" to 18" wheels. Something about the C5 calipers causing lots of clearance problems with 17's.
03-10-2005 #3dennis68 GuestMy Centerline 17X9.5" clear with about 1/100" left. It is hit and miss. Some 17's will clear the C5's and some won't.
03-10-2005 #4Understood- It's a drop-center problem. Is it just that these brakes are that much taller than the Baers using the C4 style caliper? I know they are, but I think something is still amis here...
03-10-2005 #5dennis68 GuestYes, there is a huge difference in the overall caliper height between the C5 and C4 calipers. There are quite a few guys running 13" C4 set-ups.
03-10-2005 #6Yep- knew that, too. I measured a set of Budinks and a set of BS wheels with the same drop centers; it looked like it was going to fit no prob.
Billet Specialties was told that you have to use a 17x8 with a 4" bs to get them to fit on a 68; anyone with that combo?
03-11-2005 #7I just finished installing the TC C5/Hybrid kit as well. I have 17" TTIIs (17x7 - 3.95" bs) and have about 1/8" clearance between the caliper and wheel.
Did you pick up the C5 calipers from TC as well? They mill the fins off the calipers they sell with their kit for add'l clearance. Stock C5 calipers would not fit with my TTIIs.
03-25-2005 #8
