Results 1 to 13 of 13
Thread: Ordered wheels and suspension
03-09-2005 #1
Well I ordered my new wheels today. They will be Boyd Smoothie II's in 17 by 7 with 4.5" bs and 17 by 8 with 5" bs. The front tires will be Hancooks (cheapies to get me round for a summer or so) in 245/45/17 and the rears will be 275/40/17. I got them through www.Coolwheels.com and price with rim, tire, lugs, caps, and shipping was $1500. Hope the Hancooks have at least some traction for the 502.
Also ordered Hotchkis TVS kit for a small block. From what I understand the big block that I have with aluminum heads, water pump, intake, and radiator wil weigh close to that of a small block!
Justin
73 Nova, 502 ci, TKO600, Mosier Eng 12 bolt, 6 point roll cage, Wilwood rear discs, factory front discs, 250 HP nitrous, subframe connectors, Slide-a-link trac bars, 17" Boyd Coddington Smoothie II's, and Hotchkis TVS kit.
03-09-2005 #2Nova73Hatchback GuestSweet! Make sure you take pics and lots of pics as this is what i wanna do to my 73 Nova!
Sean
03-10-2005 #3
- Join Date
- Feb 2005
- Location
- Riverside, CA
- Posts
- 5
Can't wait to see some pics
03-11-2005 #4
03-11-2005 #5Re:
Hey Dan,
Datsbad had quoted me this:
"thanks for the compliments . the wheels are budnik sparks , 18x8 fronts with a 4.5 bs. the rears are 20x10 with a 5.25bs. there is a bout 1/4 room between the tire and the lip from rubbing . it rides so nice and does not rub anywhere. the rear lip is about 4.5 deep . it really looks great at the rear with that lip . remember these are the fat lip series wheels, they give you the appearance of a wider wheel with the way that lip is designed"
So the way I saw it was that if I had 17x7 with the same backspacing I would not rub on the front. On the rear I split the difference that you and him both had for backspacing, he had 5.25 inch bs and I beleive you told me (without checking my saved messages) you had 4.75 or 4.5 So I split the diff. I figured if I had to much bs on the front I could always through in a spacer, but if I didn't have enough I was up the creek with no paddle. I couldn't find the e-mail he dropped me, but I beleive the tire Datsbad was running was even wider yet! I don't have the tires mounted yet, but the rims will be what the rims are. The wheels will be done at Boyds on the 28th then back to coolwheels to mount and balance the tires! Do you see any problems? If so I can always call and get the tire size changed round. The TVS kit is only supposed to be a 1.5 to 1.75 drop in the front! or was I informed wrong! Let me know, thanks DanJustin
03-11-2005 #6Justin, My concern with the rear clearance is minimal. Are your fender lips rolled/trimmed? If not you might have some rubbing problems on the outer portion of the rear tire. You'll be fine on the inner rear. As a matter of fact I'm going to a 275/40 next time I replace my tires, if the 8" rim will handle it.
On the fronts you're sure to rub on the inner fenderwell when turning. If your car sits as low as mine on the front you'll also rub on the outside upper fenderwell when turning. Specifically the centermost fenderwell bolt - I changed mine to a button-head cap screw for more clearance and less chance of cutting. That'll be worse if you use a spacer. Don't get me wrong, I think it'll be fine for straight line driving, it's only when turning somewhat sharply and/or entering an inclined area (front suspension compressed) that you have rubbing problems.
My TVS kit only dropped the front ~1" over stock, but then again I got the BB coil springs (which I'm going to have to cut 'cause I want it another 1"-1.5" lower).
I CAN'T WAIT to see pics of your Nova with those wheels! Please send tons-o-pics!!
If you need me to take any measurements/pics/whatever just let me know.
HTH,
Dan
03-11-2005 #7
