    Results 1 to 2 of 2
      Chico, California Nor-Cal
      symptoms for too small master????
      The peddle bleads firm, but when the car is started and the power asist kicks in, the peddle has very little pressure until the end of the stroke, then the brakes grab. The peddle also returns kinda slow. I have dual 2 1/8" Howe calipers on the front, and
      2 3/4" caddy calipers on the rear. My master is a 15/16 or 1" 4th gen Camaro master 1997. Is it just not moving enough fluid to push that much piston?
      thanks
      Keith
      Yes. You need a 1.125"-1.25" or a QTU master with the 2.125" dual piston Howe fronts.
