    Results 1 to 15 of 15
      Apr 2003
      chbg, pa
      who makes tires for a 19x12 or 20x12?
      anyone know . we have a convertible 69 being mini tubbed now . we would like to do 20" but not sure if a tire is made for a 20x12 wheel ? 19's may work
      Nov 2004
      NW Arkansas
      We are doing a Willys right now with a 20x12! We got tires from tirerack Pilot sport 2 (335/30R20)! Not the coolest tread pattern but they are huge!
      KENNY DAVIS HOTRODS
      Apr 2003
      chbg, pa
      thanks . i really do not like the tread pattern but if its the only thing out not much choice huh? thanks again
      La La Land, CA
      Pirelli
      I had a 67 Camaro that left my shop with a 345/25/YR/20 on the rear.
      Tyler
      Nov 2001
      Sacramento Ca
      a pic of a pirelli
      Tony Langlois
      1966 Corvair Monza
      Apr 2004
      Yuba City, CA (bout 1/2 hour north of Sacramento)
      theres a red camaro in Camaro Performers this month running 20x12s out back I believe it was at SEMA as well not sure what tires hes running tho.........
      J.T.
      Apr 2003
      chbg, pa
      Quote Originally Posted by ViperBlue68
      i did see that but i think it was a misprint to his tire size . it said i think 235/35/20 . which could not be possible.
      does anyone know what the complete width is of a tire that will fit with the DSE kit ? what is being used for a section width on a 12" wheel .
      Nov 2004
      NW Arkansas
      Micky thompson is also making a tire in various sizes for 20' wheels! But I don't think you can get your hands on them yet they have a wicked tread pattern! Look at the pics of the autorama and look at the truck with the lift off front end and lift up bed it has the MT's on it! We tried calling they said not tell the end of the year!!
      KENNY DAVIS HOTRODS
      New York City
      The red Camaro that's in Camaro Performers has 295/40-20s on the back. At least it did when I saw it in person. Tooo smallllll - LOL
      Aug 2003
      Orlando, FL
      Prodigy runs 345/25/20s. Pirrelli asemetricos One thing to be very carefull on a 69 is rubing. The 20s are nearly 28 tall where as a 335/30/18 is under 26 tall. 345s will rub big time if you lower it at all.
      Also, 345s are to wide for standard offset spring / mini tub kits. We are able to use them on Prodigy because it is a full chassis, no leaf spring, full tub project.
      Mar 2003
      Make it big
      Are the side walls on the 345/25/20 almost the same as a 345/30/19?
      -David
      Jun 2002
      Long Island, NY
      Quote Originally Posted by F70t/a
      Relatively speaking, they're similar, but considering how small the sidewall is, there is a difference.
      You can figure out the sidewall height by using the following formula: Section Width X Aspect Ratio (as percentage) / 25.4
      That will give you the height of the sidewall, and in order to find the total height, simply double the height you got for the sidewall, and add the rim diameter. (The 25.4 is the conversion for MM to inches).
      So for total diameter use Section Width X Aspect Ratio / 25.4 X 2 + Rim Diameter.
      To answer your question:
      345 X 25 % = 86.25 / 25.4 = 3.395" Sidewall
      345 X 30 % = 103.5 / 25.4 = 4.074" Sidewall
      So, the difference is about .7"
      mo
      i got info on the mickey thompson street radials from my mt rep size are.for 18 and 20 inch wheels theres also 15 for those who like the old school look.
      24-5-18
      26-6-18
      26-8-18
      26-10-18
      26-12-18
      29-18-18
      31-18-18
      33-22-18
      29-18-20
      31-18-20
      33-22-20
      i manage to talk him out of a couple display tires.look real cool
      will be out for sale the first of august.
      i dont have scanner or i would load the pics.
      Thall shall fear no amount of boost, For thy bottle is with me.......
      Miami, Florida
      carrera gt
      The Porsche Carrera GT runs 20x12.5's with Michelin Pilot Sport 335/30ZR-20's on the rear.
      chambersburg
      I found a 325/25/20 michelin . 12.9 section width and 26.1 tall . this is very close to a 335/30/18
