View Full Version : Bilstein Hotchkis Rear shocks
bkeith65
02-15-2009, 03:23 PM
I just went to install my rear shocks in my mono leaf shock plates on my 68 camaro and it looks like I will have to drill out the shock plate hole for the lower shock bolt?? It seems as if there won't be much material left after I drill 5/8 hole through the shock plate....anybody done this??
Brian
chicane67
02-15-2009, 04:05 PM
...Have always used the steel sleeve insert that came in the box from Bilstein... and the factory bolt size. Never drilled the holes... I always used the sleeves.
This is something you could get from Bilstein in Poway, ASI is El Cajon... or even ORW would most likely have these laying around.
bkeith65
02-15-2009, 04:49 PM
Thanks Chicane..so the sleeve goes in the lower shock "eye" and then the bolt through the sleeve?
chicane67
02-15-2009, 05:07 PM
That is correct.
bkeith65
02-18-2009, 03:03 PM
Found them at Summit Racing!
texasdvldog
02-07-2010, 08:54 PM
looking for the same thing! Have a part number for them?
texasdvldog
09-08-2010, 06:03 AM
still looking for the part number! i saw a few of them but not sure exactly which size is the one i need! HELP! :help!:
CarlC
09-08-2010, 06:48 AM
Have you tried contacting Hotchkis?
