MilesSpeed
02-09-2009, 03:21 PM
Test your friends...
www.kalecoauto.com (https://www.pro-touring.com/forum/www.kalecoauto.com)
this website is hilarious!
Some examples...
Lowering Kit (http://kalecoauto.com/index.php?main_page=product_info&cPath=4&products_id=11): 4-pc nail set
Some people spend hundreds - even thousands merely to lower their car! Some people even cut their springs - that is the wrong way to lower a car! Why bother with different bolt sizes and components, when KaleCoAuto's do-it-yourself lowering kit is a mere four piece kit! Installs in minutes, just insert one per tire and you'll be the envy of every lowrider in town! Now available in standard, chrome, and gold.
Polishing Pads (http://kalecoauto.com/index.php?main_page=product_info&cPath=4&products_id=42) - With wear indicator
Within every pad, are a series of metal spikes. When the pad is worn out, the foam breaks down, then the metal spines penetrate the cloth, and leave a visual indication on your vehicle, so you know when it's time to replace the pad! Compatible with any common buffer, or can also be used by hand.
Spark Plugs (http://kalecoauto.com/index.php?main_page=product_info&cPath=2&products_id=5) - block spark
Spark plugs are often misunderstood by most people. A spark plug's name is quite literal. They are designed to plug the line - and suppress any spark that may come through. Of course, you know what happens if a spark finds an open fuel source!! That could get ugly! KaleCoAuto extra retardant plugs block 99% of spark, and allow 95% of ignition molecules to pass through. That's 25% more than the competition, and unlike the competition, KaleCoAuto plugs never need cleaning.
Sorry if this is a re-post!
Some examples...
