Results 1 to 2 of 2
Thread: C4 IRS into 1st Gen Camaros
02-08-2009 #1
- Join Date
- Aug 2006
- Location
- Richland, WA
- Posts
- 36
Howdy Guys:
I'd like to get a little help for putting a C4 Dana 36/44 into a 1st gen Camaro.
For staters I have templates of and have fabricated the brackets offered by Wayne Due a few years ago. The problem I'm having is that using the brackets at the desired ride height (245/40/18 = ~ 25.7") and 1" vertical clearance to the fender leaves the half-shafts at -4 to -5 degees (angled up). The second problem is that even with a 5" backspace the rims/tires extend out past the fender. The width of the C4 IRS will force significant rim backspace and/or narrowing of the half-shafts in order to fit within the fenders. If you narrow the half-shafts and use the factory control arms ("dog-bones") you are limited by the frame rails. It looks like you can gain ~2" on each side. If you do this the camber and toe-in rods will also need to be modified.
Here's some specifc info. I'd like your thoughts on:
- What is the optimum (factory?) angle for the half-shafts? I know 2-4 degrees is typical for driveshafts but I would think that negative (sloping up) not only looks bad but also is not optimal. Is 0 degrees what I should shoot for? Strikes me that ~2 degrees sloping down seems right?
- What about half-shaft angle front-to-back? Are the half-shafts intended to be in the same plane (straight with each other up and down) or are they too angled?
- What angle should the control arms be set at. It appears the lower control arm is set at ~15 degrees for the Corvette. Should this same angle be the target in a conversion?
04-24-2009 #2
- Join Date
- Feb 2006
- Posts
- 52
do a google for c4 lowering kits for your modified control arms etc.
i would get a suspension modeler or find some nice person on here to 'redesign' the suspension for you if you are going to narrow and/or not use the factory specs.
there are huge flaming debates on here about the effects of narrowing an irs. tread carefully!
