View Full Version : power steering delete
s4dustin
02-05-2009, 07:16 AM
Anyone make a power steering delete? Have a lq9 in my 68 and i need the power steering pully without the power steering to complete my lq9/magnachager/t-56 front accessories off.
WS6
02-05-2009, 01:32 PM
it's going to depend on what accessories you are using; truck, fbody, gto, vette,... I' can't imagine it not being out there but if not, it wont be hard to make one that bolts across the bracket where the ps pump was.
Shawn MacAnanny
02-08-2009, 07:12 AM
Are you still rung AC and stuff? I am running just an alternator and water pump with just a shorter belt. You dont need dummy pulleys.
I just saw you are runnning a magnacharger, perhaps you do have to rou your belt different for it.
WS6
02-08-2009, 04:34 PM
if you are running fbody accessories, you're correct in that you don't need a dummy pulley. We need more info from Dustin before we can fully answer him though. I know on the vette, the Maggie belt is very long and I'm not sure you could find the proper length belt by bypassing the PS like you can on an Fbody. It's worth power if it can be done. ~10hp
s4dustin
02-14-2009, 07:44 PM
I put a pulley through one of the Powersteering bolt holes with a spacer a friend made. Seems to work well. The belt appears to be tight enough.
Next step is the gas tank, fuel lines and the hyrdrolic clutch kit from ATS.
I will post pics tomorrow.
Thanks guys,
D
s4dustin
02-22-2009, 06:27 PM
some pics
https://static1.pt-content.com/images/pt/2009/02/IMGP0009-1.jpg
https://static1.pt-content.com/images/pt/2009/02/IMGP0008-1.jpg
WS6
02-22-2009, 08:05 PM
good job Dustin
