View Full Version : Fuel Pick up questions
Crossupbill
02-03-2009, 03:26 PM
Hello, I am building a 1979 Malibu and have a few questions about the fuel system. I want to run a factory style fuel tank but must have constant fuel supply or else (turbo BBC). I have read about the fuel cells and all that and do not like the look of a big square box hanging down in the back. I also want a trunk that is useable. Is there some type of fuel pick-up that I could build or sump that I could make to keep fuel to the engine during braking,acceleration, and cornering G's? I will not spend the money to have a custom fuel tank made, 1000 bucks is a bit much for me.
Ryan
poormans69
02-03-2009, 03:51 PM
I was wondering the same thing. Hopefully someone will chime in.
This is what I've found so far.
https://www.pro-touring.com/forum/showthread.php?t=281
http://www.iimuchfabrication.com/Tanks/
http://www.geocities.com/hrayhouston/antisurgetank.html?20093
86Cutlass383SR
02-04-2009, 08:37 PM
I was going to mention the dropped tank sumps but I guess that is the big square box you don't like to see hanging down.
I tried... nevermind.......
I need sleep
Crossupbill
02-06-2009, 05:27 AM
Well not really, the big box I do not like is something like the fuel safe cells that hang down. A sumped tank would be fine but I do not see how that would contain enough fuel to keep the pump supplied in cornering. Maybe it would, that would be an easy fix.
Ollie8974
02-06-2009, 06:36 AM
Check this out.
http://www.ls1tech.com/forums/conversions-hybrids/962620-efi-gas-tanks-gm-cars-55-81-f-body-chevelle-tri-5-a.html
The WidowMaker
02-20-2009, 09:07 PM
heres another i started on the chevelle site.
http://www.chevelles.com/forums/showthread.php?t=261083&page=1
pete09
05-04-2009, 07:24 PM
This is a set up for a Mustang but the same thing can be done to just about any tank.
http://www.glennsperformance.com/product_info.php?cPath=28&products_id=145
If this motor is going to require a large fuel system (As I would assume it would) then you really should think hard about a sump.
Those big pickups are fine but I would not use them over 400 ish HP that's me though. That said I've used the stock system up to that power level N/A. It was undersized but I had no problem with the pump having to suck out of the tank while running a small suction filter. In a forced induction set up I would not want to take any chances on going lean so err on the side of caution and sump your tank is my advise.
