Results 1 to 3 of 3
Grand National power Steering gear box
My Regal has a a brand new (1yr old) front suspension, Idler arm, center link, inners & outers, new poly Bushings, upper and lower ball joints, poly end links and sway bar bushings, with a GN front sway bar, with Oldsmobile G-body 307 olds front springs.
And the GN power steering gear box with the pitman arm.
Recently I have been experincing having a looser feel to the steering wheel like having to steer more before it seems to respond.
Im using a the power steering pump that was orginaly on the 71 Buick 455 that is now powering my ride.
Didnt know if the pump is correct or do I need to use the one from my GN i got the Gear Box from,because it worked great in my GN.
Didnt know if anyone has done this swap before and what they did to tighten up the feel, for a better "ROAD FEEL" and not driving a padded Caddy.
Later
Later
Chris Reed
Vice Director of the Indiana Buick GSCA Club
"STG1RGL"
82 Regal (in 87 sheetmetal) w/Buick Big Block 455
(R.I.P. lost in my garage fire 01/09/14)
www.cardomain.com/id/stg1regal
7.5 G's Rule!!!
