View Full Version : GM LSx controller kit - see it here
Bowtie racing
01-18-2009, 09:06 AM
Heres whats included in GM Performance LSx controller kit
http://www.gmperformanceparts.com/Pa...roller_Kit.jsp
https://static1.pt-content.com/images/pt/2009/01/DSC02945-1.jpg
So far i am really pleased with the kit. Everything is clearly marked and well packed. The fuse/relay box could be smaller since i plan installing it under dash. Its quite bulky. Something i think was a lot better in Speartechs system. Missing from the pic are clear and easy instructions.
These comes with the kit:
Engine Harness
Mass Air Flow Meter
Mass Air Flow Meter Mounting Boss
Accelerator Pedal Assembly
Oxygen Sensor (2) Per Kit)
Oxygen Sensor Mounting Boss (2)
Instruction Sheet
I bought mine from forum member Jeff Tate https://static1.pt-content.com/images/pt/2007/09/cheers-1.gif !!
Jeff got me a good price , excellent customer service:1st: and he did found all the answers for my wierd questions.
Thank you again Jeff!!
Malibu Jax
01-18-2009, 11:35 AM
Out of curiousity, what is the price of that nice setup?
neki67
01-18-2009, 11:36 AM
I've got the exact same kit and when you mean that you have clear and easy instructions, I would like a copy, cause the instructions I have are very minimal (in my opinion).
Bowtie racing
01-18-2009, 11:41 AM
Thats the reason i say they are clear and easy. No need to read 1000 page thick manual...;)
Bowtie racing
01-18-2009, 11:43 AM
It goes under 1000 bucks if do some search. But i would recomend you to contact Jeff when shopping GM parts. He has good prices and excellent service.
JEFFTATE
01-19-2009, 05:52 AM
Thanks Joni !
I'm glad you like the kit.
Let me know how it works !
I just got back from working the GM Performance Parts display at the World Of Wheels car show in Atlanta , Georgia.
I must have talked to one hundred people about the LS Controler Kits.
There seems to be a lot of interest in these products.
Bowtie racing
01-19-2009, 07:52 AM
Hello Jeff !!
I definetly keep you posted!! Next step is to get those 2 LS3s with controller to work .Then is time for my project. But i need my motor before that.. You will be the first one to know when i need it.:cheers:
andrewb70
01-19-2009, 06:41 PM
I have one in my GTO. Works well. I would recommend ditching that godawful pedal and get a pedal from a 2007 Monte Carlo SS. I am sure Jeff can help with that as well. It should be less than $50.
CarlC
01-19-2009, 06:42 PM
Considering that the power center will handle fan(s), pump(s), engine power and accy's, plus it has a ton of expansion capability, it's really not all that large. And for the price it's a great bargain in the long run.
Steve1968LS2
01-19-2009, 06:49 PM
And if you want to run a throttle by cable can it do that as well?
Looks like a good option.
Damn True
01-19-2009, 06:51 PM
Nice.
Hey Jeff, what's the damage on that setup?
...and can a guy substitute the Monte Carlo pedal?
Damn True
I thought I recalled reading in a "hot parts" thing in one of the major mags that it could.
andrewb70
01-19-2009, 07:01 PM
No can do. I had a conversation with John at Speartech a while back. He said that all LSx engines that use a 58 tooth reluctor wheel must use the DBW.
Bowtie racing
01-19-2009, 11:27 PM
!!!! I didnt even think i can expan it ! Thank Carl for the tip :cheers:
CarlC
01-23-2009, 05:21 PM
Given the cost of a 90mm cable operated throttle body vs. the DBW throttle body that come with most used setups or crate engines, the DBW is far less expensive and easier to install. I have not yet looked into it but I may, if the TB is big enough, try to swap in a C5 DBW into mine in order to have better pedal placement and tuneability.
gkring
01-23-2009, 06:54 PM
Very little info on these controllers. Looks like a stock kit and one for the 480 HP crate motors? What is the difference between the three controller part numbers? If I did one and later did a cam swap or something similar can the ECM be tuned with HP tuners? Maybe it is just a matter of getting a VIN into it and then it is game on? if you knew you were going to retune and didn't care about the preprogrammed tune does it even matter which kit you got?
The WidowMaker
01-23-2009, 07:49 PM
does this mean any aftermarket 58x kit must use dbw? or is this only for the gm controller?
Tim
neki67
01-24-2009, 04:42 AM
Very little info on these controllers. If I did one and later did a cam swap or something similar can the ECM be tuned with HP tuners? Maybe it is just a matter of getting a VIN into it and then it is game on?
Jesse from SDPC wrote the following on 10-13-2008 in another thread:
The $949 controller as it sits needs to be tuned once everything is installed in your car. EFIlive just made things easier, you now can tune them using EFIlive as they sit without having a VIN installed into the computer. We discussed this and it has now been confirmed with EFIlive that it is possible. HPtuners is beta testing the same compatibility, but it is not in place yet and you do have to get a VIN put into the ECU to tune it.
It seems like the best option right now if you want a standalone computer, especially now that these companies are giving you the option to tune them with more ease.
