View Full Version : '68 Camaro. #2 wire off headlight switch. Where does it go?
Larry Callahan
01-11-2009, 07:38 PM
At the moment I can't find my chassis manual. Can someone look at a '68 Camaro manual and tell me what the brown wire that comes off pin #2 on the headlight switch goes to?
It's getting way too hot. I think I may have a short or I have hooked something into the wrong circuit. This is also causing that coiled resister type wire to glow red hot.
I suspect it is the dimmed dash light circuit.
MuscleRodz
01-12-2009, 08:45 AM
Factory harness or AAW?
Larry Callahan
01-12-2009, 09:54 AM
It's a 10 year old Painless harness
MuscleRodz
01-12-2009, 10:20 AM
that is even worse. brown should be park lights, grey would be guages, yellow dimmer, white courtesy ground, the others are not coming to mind, should be a couple more.
01-12-2009, 11:00 AM
yep should be park lights....if its getting hot, check to see if your lighting ground isn't loose or on paint.
