Results 1 to 3 of 3
01-10-2009 #1
- Join Date
- Jan 2008
- Posts
- 86
Will 80s G-body proportioning valve work on 71 a-body?
I changed over my stock front drums on a 71 cutlass to discs years ago. At the time, the car craft article said I didn't need to change the distribution box to a proportioning valve. Well, I'm doing other changes now so I want to have a proportioning valve in. I found one off an 87 Monte Carlo SS in the junkyard; can this go directly in to a 71 Cutlass?
Thx for your thoughts.
01-10-2009 #2
- Join Date
- Dec 2004
- Location
- North Jersey
- Posts
- 983
I'd imagine the SS disc/drum prop valve should work just fine for your car, as far as the bias goes. The only issue you might have is the fittings; I'm not positive, but they might be metric threads. I've never had mine apart to verify.
Steve Ragusa - North Jersey
2006 Infiniti G35x
01-10-2009 #3
- Join Date
- Jan 2008
- Posts
- 86
I made sure to get all the fittings going into the proportioning valve. I'll just get some lines that I can add the fittings to.
Thx
