    Results 1 to 6 of 6
      Jun 2005
      Manassas, VA
      Electronic Speedo Converter Choices
      Doing a 4L80E swap, and am looking for choices in speedo converter boxes. What are the 'good' ones, which will get you by, or does it make more sense to just change the speedo to an electronic one?
      HWYSTR455 on PY
      1971 Lemans Sport 461 bottle fed daily driver
      1971 Trans Am 474 blown EFI pro tour car
      1972 442 W-30 clone
      Jan 2003
      Arizona
      Typically, it makes more sense to just get an aftermarket electronic speedo to match other gauges and take advantage of added features. As for a factory speedo adapter unit, they can be pricey, but speedometers can be finicky. So go with these guys for zero head scratching.
      http://www.abbott-tach.com/Cable%20X.html
      ________________
      Steve Chryssos
      Jun 2005
      Manassas, VA
      Well, since the factory speedo has the high beam indicator and turn signal lights, was kind of hoping to keep it, since I don't feel like going through the hassle at the moment to 'do it up'. Saw the cable-x boxes, and pricey is right. Saw the tail housing replacement ones too, even more pricey. Trying to see what my options are here, may end up just throwing a cheap-o speedo on the dash until I get around to doing the gauges.
      HWYSTR455 on PY
      1972 442 W-30 clone
      Nov 2004
      Colorado
      I am selling an abbot box check the fs forum if interested.
      I used it with a 4L80e and the factory speedo in my 69 Camaro.
      Jun 2005
      Manassas, VA
      BTO has the cable-X boxes new for 293.00, and several other places have them for $310. The least expensive I saw it was $274.95, which is still more than what the speedo I am considering switching to is. If I hold out, should be able to get one off eBay for under 200...
      HWYSTR455 on PY
      1972 442 W-30 clone
      Nov 2004
      Colorado
      Thats why the price says OBO. Make an offer.
