Results 1 to 6 of 6
12-31-2008 #1
- Join Date
- Dec 2006
- Posts
- 47
'69 Falcon, front disc kit - but w/GM bolt pattern?
Greetings,
I have a '69 Falcon stationwagon. A previous owner swapped on a set of Grenada front disc brakes (still have the rear drums, and a manual master cylinder - don't plan on changing any of those for now).
I have some wheels I want to use, but they are GM (4.75") bolt pattern. I found someone that can re-drill the rotors, but they want $150 or so, and I'll have to do it again if I ever need new rotors.
I prefer a kit that will stop at least as good as what I have, but knock some weight off the front of the car. The wheels are 15" diameter, but previously fit fine on a car with the Baer kit (GT, I think) w/12" rotors and PBR calipers.
Lee
- '72 Cutlass Conv., 455, E's, Baer, 700R4, Boze wheels
- "65" FF Cobra, efi302, t-5, 12.5 @ 106
- '69 Falcon Wagon, 351W, 4R70W, 3.50 9", elec. fan & waterpump, current best of 11.65 @ 117.6
01-02-2009 #2
- Join Date
- Apr 2006
- Posts
- 134
Some Mustang II brake kits offer the choice of granada rotors, or some kind of GM rotor. They might fit. Find out what they use. But the rear axles have to be drilled or changed.
01-02-2009 #3
- Join Date
- Dec 2006
- Posts
- 47
Terry,
Thanks for the lead!
Rear axles (31-spline, shortened 2" each side, Moser's) are already taken care of
Lee- '72 Cutlass Conv., 455, E's, Baer, 700R4, Boze wheels
01-16-2009 #4
- Join Date
- Apr 2006
- Posts
- 134
Found some more on it. The rotors they use are 68-72 GM mid-size. (chevelle etc.) But the bearings and races must be swapped into them from the ford.
01-19-2009 #5
- Join Date
- Jan 2006
- Location
- Oregon
- Posts
- 1,773
