    Results 1 to 5 of 5
      Oct 2007
      central, KY
      How much room can I gain from drum to disk swap?
      I would like to tuck my new 275/40/17's in, just slightly more, for perfect fitment.. How much space gain I gain going from standard rear drums on a GM 12-bolt to a Baer rear disk setup??? Thanks...
      - Mark
      67' RS Camaro - 468/476hp, polished, show car
      68' Camaro drag car-507/752hp,-13.1:1, only 241 miles
      79' TransAm- 540/763hp, Dave Monday custom built chasis,pump gas-10.2:1, LSM,CFS,Callies,AFR
      80' Z/28- all original, black w/ red stripes, 2nd owner, loaded, all paperwork - excellent driver
      Marshall , MO
      Swapping to disks usually will add to the track width not decrease it.
      Brad Shepard
      69 Malibu
      Marshall, MO
      Chicago suburbs
      The drum or hat (disc) both usually sit against the axle flange, so besides the actual material thickness, there should be no change unless you narrow your rear or change wheel offset.
      Aug 2003
      Orlando, FL
      You will gain 1/16" of track width
      North Jersey
      Quote Originally Posted by shep View Post
      Yep, I found that out when I did a rear disc conversion on my Cherokee. The hat on the rotor was thicker than the face of the OE brake drum. I even needed to install longer wheel studs to compensate for the wider track.
      Steve Ragusa - North Jersey
      2006 Infiniti G35x
