View Full Version : broken reluctor wheel
TMat
12-22-2008, 07:11 AM
So I was putting the vacuum advance canister back on my MSD distributor and I broke one of the teeth off the reluctor wheel. I have a new reluctor and I knocked the roll pin out of the cam gear. The gear won't come off.
Am I doing this right?
69keith
12-22-2008, 01:47 PM
I think it must be pressed off...but be very careful and do not bust the gear.
12-22-2008, 09:07 PM
Sometimes the roll pin makes a burr on the shaft and makes gear removal harder but it shouldn't be too difficult to remove it.
TMat
12-23-2008, 07:00 AM
so it should come off by hand? It seems to be on there pretty tight.
12-23-2008, 07:20 PM
The one I changed a while back on an MSD distributor pulled off with hand pressure only. Yours might be different.
David
gggoad
12-23-2008, 09:00 PM
Keep in mind the reluctor wheel has to be put on exactly in the same position. You can buy the tool but it costs about $200. I am having one done at Boyds Machine in Norman OK. They heat the crank, then press the new wheel on - costs $25, you can buy the new wheel from GM. That is the only way to fly in my opinion.
LowBuckX
12-26-2008, 12:37 PM
He is talking about the pick-up reluctor on an MSD dist...
MonzaRacer
01-01-2009, 08:35 AM
If your replacing it simply use a propane torch to warm it up , careful of any plastic in the advance mechanism best to disassemble it first, then it should come off with minor difficulty, then slide a new one on, if I remember correctly its the same one as a Ford V8 available from local parts houses.
Good Luck
