    Results 1 to 3 of 3
      Nov 2007
      Aurora, CO
      Metal finish question
      How do you Body/metal fabricators acheive the brushed finish look on your body panels? After welding I use a 4-1/2" grinder on thicker metals or my 2" angle air sander on thinner metal to knock the weld down. I use 36 or 40 grit discs then finish it with increasingly finer grits like 180 or 220. last I use a scotch disc for my finish. I get more of a polished look than the brushed look you guys get. I worry that a primer coat won't adhere very well to the polished looking metal.
      Ron
      Feb 2008
      Denver NC
      D/A Sander?
      finish with 80 grit on bare metal for primer finer then that you start polishing the metal
