    Results 1 to 14 of 14
      Jul 2008
      ohio
      cheap disc brake alternitive
      wanting to convert my rear drums to disc but don't have the money right now to go out and spend the money on big name brand brakes so i was wondering if i can get 4th gen camero brakes to fit on the back if so could you tell me what exactly i need to get from the car i'll get the brakes off a car in the junkyard.I work in a automotive plant so you could imagine how much i'm working now, so it will still be a while before i can get those but wanted to know ahead of time so i can be prepared when i have the money
      Jul 2002
      Mesquite, TX
      All of the rear brakes including the backing plate/brackets (which looks like it will require that you take the axles out of the houring of the donor car - definitely on the LT1 era 4th gens, not so sure on the LS1 era).
      You might (or might not) want to grab the park brake cables and maybe even the master cylinder.
      Jul 2008
      ohio
      you mean all these people that viewed this thread did'nt know the anwser just kidding LOL!!!!
      Jul 2002
      Mesquite, TX
      Actually, it's more likely that since the information would have been found by a search they didn't bother replying.
      Searching on "LS1" or "LT1" in the Disk Brakes forum comes up with a long list of posts. They're not the most intuitive search terms, but since the 4th gen rear brakes changed when the engines changed the designation works pretty well.
      Dec 2008
      Albany, Ga
      you can use the 93-97 (LT1) brakes and still have a parking brake. IDK which cable you need, but it can be done.
      if you use the 98-02 brakes, you will have to do some custom fabbing to even have a way to hook up a cable.
      Marshall , MO
      Model and year of car would help as well. f-bodys are different year to year and different from the a-bodys
      Brad Shepard
      69 Malibu
      Marshall, MO
      Feb 2006
      Idaho Falls, Id
      I haven't tried to install them yet but I bought a complete set of rear "ls1" brakes on ebay for less than $200. I'll be putting them on a 9" though so I'm sure there will be some fabrication required but I know others have done it.
      Traven
      Los Angeles
      Off a '98-'02 donor car, you need to pull the axles and get backing plates, calipers, rotors (replace with new ones are recommended), parking brake cables, and anything else you see there.
      Current: 2010 CTS-V
      Sold: '65 Pontiac, '08 TBSS
      Sep 2008
      Kathleen, GA
      if at all possible use the LS1 stuff, the LT1 style E-brake is worthless, especially in a heavy car
      New Carlisle Ohio
      PartTime
      Chris Hager
      Oct 2006
      So Cal San Dimas Ca.
      Dec 2008
      Lehigh Valley Pa
      Ok I have checked out the LS1 rear disc brake set-up and think it might work for me if I drill the rotors out for my 5X5 bolt pattern. Not because of the emergency brake in the rotor I am wondering if I could even do this. Anyone know for sure?
      1996 Federal Cadillac hearse
      1988 Eureka Chevy hearse
      Nov 2004
      Dallas Texas
      rear discs
      Quote Originally Posted by The Stickman View Post
      the cadillac sevilles 77 and later had rear discs with a 5x5 bolt pattern that will fit but theyre 10.5: rotors and rear actuating calipers(junk IMO) with a self adjusting calipers
      Rich
      69 Trans Am "TireBird"
      M6 / LS6 minitubbed DSE Sub
      C5 frt LS1 rear disc brakes
      https://www.pro-touring.com/forum/showthread.php?t=14992
      69 R/S Z28 302
      15 Camaro ZL1
      90 Formula next project
      Holmes Hollow, Ontario Canada
      There should be a sticky on the first gen / fourth gen brake swap. I just asked a question like this and I'll bet there's been lots of people asking the same thing. Its a good question and its what hot rodding was built on - who has the expertise on this?
      ____________________________________________
      Scott
