View Full Version : oil pan
k7king
12-10-2008, 07:29 AM
What oil pan and motor mounts do I need with a Ls2 engine and the stock 350 transmission in a 2nd generation camaro? The car sits low so the pan can't be below the crossmember.
Mike
TX79Z28
12-10-2008, 02:25 PM
Mike
I am doing essentially the same (except LS3) in my 79, take a look at these guys. When I am ready for the swap, I plan on going with them, unless I find a better source by then:
http://www.brphotrods.com/1970-1981%20camaro%20firebird.html
Shawn MacAnanny
12-11-2008, 05:43 PM
t56kit.com has an amazing oil pan and mounts. I would have definately gotten their oil pan if i had known about it when i bought my moroso. The Moroso pan is still pretty nice though.
You'll need a crank spacer for the TH350 or a special made TCI converter for the swap. I think its around $600. You'll also probably have to adjust you crossmember a little bit. All of the bolt holes will line up you will jsut have an extra one on the block is all.
