View Full Version : Wilwood Plumbing
griff
12-08-2008, 09:33 AM
I am looking for any tips you guys might have on plumbing the brake lines on my 68” Camaro. I am installing a Wilwood master cylinder and Wilwood disc all around. I am not a very experienced tube bender but I guess I will learn.
Any recommendations on supplies and where to get them? I was going to order a stainless, disc brake conversion kit from Inline Tube and use what I could out of the kit. Any input is appreciated.
--Griff
6'9"Witha69
12-08-2008, 03:49 PM
The inline tube stuff is great. No matter what you will need to modify the rear disc lines into the calipers. A good double flare tool will serve you well.
65chevelleboys
12-09-2008, 10:17 PM
by good he means a$200.00 flare tool.
griff
12-10-2008, 09:30 AM
TLF01- 37 Deg Single Flare Tool - $125.00
Flares: 3/16", 1/4", 5/16", 3/8", 1/2"
This tool is designed for single flare 37 degree flare applications. This tool provides smooth, uniform flares for A/N connections using steel or stainless tubing.
This is the one I was going to order.
redhead
12-10-2008, 09:35 AM
inline sells a ss kit with straight sections for you to bend.
comes with a bunch of hw and fittings etc.
I did my 68 camaro in wilwoods a few months ago.
it was my first experience bending and flaring.
had no problems but I did spring for an expensive flaring tool.
every flare turned out perfect from the get go.
I did not go with modding a pre-bend kit due to the expense
and having to add extra (unclean) bends.
besides when you are done you can always resell the flare tool.
dcozzi
12-11-2008, 12:46 PM
Is a single flare for fuel lines and double flare for brakes?
6'9"Witha69
12-12-2008, 09:24 AM
Is a single flare for fuel lines and double flare for brakes?Pretty much. You can use a crush sleeve as well on SS lines as the harder more brittle material needs a little more sealing power.
thedugan
12-18-2008, 07:47 PM
Does anybody now can the Rigid 377 do a double flare for a brake line?
thedugan
12-18-2008, 07:50 PM
also I'd like to use this as its the best tool I have for stainless line. I used it for my fuel line AN fittings and it worked real well
thedugan
12-19-2008, 11:08 AM
Well its snowing so great day todo car projects. If anyone knows if the 37 is cool for brake line fittings let me know.
