View Full Version : help which brake line flare tool for stainless lines
65chevelleboys
11-22-2008, 10:13 PM
what brake line tool can i buy that is not to expensive .i can spend apx 100.00 trying to flare 3/16 stainless lines.thanks for your time.
thedugan
11-23-2008, 05:42 AM
I have this one from Rigid and it works great
http://www.ridgid.com/catalog/RT2004-076.pdf.
But it aint cheap
Jim Nilsen
11-23-2008, 06:38 AM
But it aint cheap
It's what I use and it will be well worth the money to anyone doing stainless. With the cost of stainless around 25 cents an inch it is a neccessity to have just to make sure you don't scrap out a much longer piece that will never be able to be bent into something else shorter. When you get down to the last nut & ferrule and go to put the last flare on and the piece fits perfect, you don't want to screw it up :seizure:
If you can afford to go stainless line you can afford the tool. You can always sell it later when you are done and might need money or you can possibly rent one at your local rental place.
Goodluck
Bow Tie 67
11-23-2008, 07:30 AM
I had a Ridgid for AN flaring that worked great.
Matt
65chevelleboys
11-28-2008, 09:36 PM
thanks guys.if i can send pics of the finished product i will.
also what model # of ridgid do u use for stainless?
#458r
#455
#375
The WidowMaker
11-28-2008, 10:17 PM
377 is used for 37* in the common car sizes
gearheads78
11-29-2008, 08:42 AM
http://www.thetoolwarehouse.net/shop/MAS-71475.html
After buying and using that I don't want to ever pick up another flair tool.
The WidowMaker
11-29-2008, 11:11 AM
the kit above is very nice, but you cant do 37* fittings. if you want AN, 71480 is the part number you want.
Tim
6768toys
11-30-2008, 04:56 PM
Sorry to jump in here with a question, but what is a good bender to go along with the flaring tool?
65chevelleboys
12-01-2008, 09:38 AM
does this tool ridged make double flare on stainless?no info on web site.
MickMc
12-01-2008, 02:50 PM
For bending stainless use a Swegloc bender, your stainless lines will love you forever.
65chevelleboys
12-13-2008, 09:37 PM
bought the mastercool flaring tool.did my first flare.wow!!!!
i like it alot.
silver69camaro
12-18-2008, 07:52 AM
i like it alot.
I purchased the kit that does 45* and push-connect (great for doing LS conversions) flares. Just a couple weeks ago I bought the 37* adapter, which was very hard to find. If you need one, let me know - only a few places will sell them at this time.
Rallye455
12-18-2008, 08:58 AM
Where can you get the 37* adapters? I have the mastercool to do 45* and would like to be able to do the 37* also
silver69camaro
12-18-2008, 12:01 PM
I bought mine from ETW in Tukwila, WA. Since the part is so new, most vendors (Matco, Snap-On, NAPA) have the "I can't find it in the computer therefor I wont sell it to you" mentality. All they need to do it call Mastercool to get pricing. Very frustrating.
Anyway, it was $10. Mastercool does sell different dies for the 37*, but it works the same with the 45* parts and using the 37* cone.
CarlC
12-18-2008, 01:58 PM
Matt,
Does the tool have any problems making the push-lock upset on -6 stainless tubing? If it can do that I may pop for one. I really like the GM OE pushlock connections.
65chevelleboys
12-18-2008, 10:31 PM
do you have part numbers.or web site?
Olav
12-20-2008, 02:33 AM
Will any of these flaring tools make double flare on 3/16 SS lines ?
Olav
gearheads78
12-20-2008, 06:59 AM
Olav
The hydraulic tool I linked to above makes it a one hande deal. I don't know how I lived without it.
gearheads78
12-20-2008, 07:00 AM
Olav
The tool I linked to above does a great job with no effort.
gkring
12-21-2008, 08:50 PM
Matt,
I tried to use it today to do a double flare on 1/2" (-8) stainless tubing and it would just push the tube without flaring. I had the dies as tight as I could by hand and was not willing to use a little leverage help to get it tighter. It may do a single flare, but I didn't try it. I doubt if it will do a pushlock on stainless. Maybe there is a softer stainless tube than what I have however. I just had this leftover from my last car. It does regular steel line wonderfully.
CarlC
12-21-2008, 09:06 PM
Why would you want to double flare a stainless tube?
BonzoHansen
12-22-2008, 11:47 AM
SS has no seam to be concerned with, which is the reason to dbl flare, correct?
The WidowMaker
12-22-2008, 08:09 PM
ive never heard of a double flare for stainless. just single flare and the brass seals. annealed stainless is much softer and will bend and flare easier. anybody know where to get it in long straight pieces?
Tim
gkring
12-22-2008, 08:51 PM
Tim
Guess that is why I have such a hard time trying to flare it. So if you did want to double flare small stainless line for your brakes you would just single flare it? The line I bought was from the local hydraulic hose shop. Straight line in at least 8 foot lengths. The larger 1/2 inch lines I bought seem pretty tough. No way I could bend them with a standard tubing bender. I had to get the larger bender with foot long handles. I'll check my extra scrap next time I am at the shop to see if the marking tell me what kind it is.
silver69camaro
12-23-2008, 05:50 AM
I've done it several times, both 1/2 and 3/8. Perhaps your wall thickness was too high?
silver69camaro
12-23-2008, 05:52 AM
Correct. But in my position, my flaring tool makes beautiful double flares in under a minute, and does a better job at double flares than single.
Rick Dorion
12-23-2008, 06:13 AM
I too bought the hydraulic mastercool tool. Initially I thought is was a bit extravagent but I've since had to do several on-vehicle repairs for various daily drivers and it's turned out to be an excellent investment. Perfect flares every time.
CarlC
12-23-2008, 09:48 AM
Stainless can crack during the double-flare process. The smaller the diameter, the greater chance of cracking. For anything -8 and under for our applications a single flare is sufficient, easier to produce, and more reliable.
For a very interesting read Carroll Smith's "Nuts, Bolts, Fasteners, and Plumbing" is a great laymans book on basics of such things.
silver69camaro
12-23-2008, 10:16 AM
Carl,
I've noticed it depends on what SS tubing you purchase. I've used some tubing I got at some local hydraulic shop, and it had small cracks every time I flared it. The tubing I use now (from Williams Oil Filter Service in Tacoma, WA) never does crack. It appears to be the same material used by Inline Tube and others. I wish I knew what material grade it is.
Karch
12-24-2008, 08:46 AM
Fully annealed is what you want.
I used to sell thousands of feet of stainless (also titanium, inconel, tantalum, nitinol).
I can't remember specifics, but the particular alloys have an effect on forming, and it's really the cold working that causes the problems.
gearheads78
01-04-2009, 09:44 AM
Tim
This is the first time I have ever used stainless and just assumed it should be double like steel tube. I have done my whole car in double flare. :hammer:Do need to be concerned? I did not see any cracks but since I was not really looking for cracks I may have missed something. The tubing was a roll I got from inline tube.
silver69camaro
01-05-2009, 06:06 AM
No, Inline Tube's lines are good for flaring.
