    Results 1 to 9 of 9
      Dec 2007
      Plastic Grill and dash fix
      Hey guys,
      Need to fix a few broken tabs on my 69 camaro grill and console any ideas on what kind of glue or epoxy to use? Also need to fix a mount on my 93 camaro bucket seat side panel. This is a different type of plastic. Any help much appreciated.
      Dec 2007
      Anybody??? Sombody has to have this problem??
      would have a pic
      1972 Camaro ( my retirement money hole )
      1985 GMC ( future plan pro tour build for the wife )
      1992 Isuzu pup bagged, bodydrop, shaved everything
      2013 GMC Single cab 4/7 drop
      Jul 2007
      Calgary, Canada
      Depends on the plastic and how it is broken. Ever heard of plastic welding? Fancy name for melting it back together. Works good on some instances, would never work on others. Basically you use a hot knife or other tool that might fit the application, melt- weld,'pulling' it back together.
      Dave
      68 Corvair coupe
      65 Impala SS
      64 Corvair Rampside
      62 Corvair Greenbrier
      Asst. daily drivers
      http://www.sourceboards.com/
      Rockford Illinois
      A good brand of superglue will usually do it if it is a clean break. If it is in pieces it's tough.
      Somtimes just riveting a piece of steel to it will work to brace it.
      It really depends on wich tab is broken and where also. A pic would really help.
      At times the plastic is so old that the only thing that really works is a new grill. I know it not what you wanted to hear but it is the truth.
      Apr 2008
      Oregon
      I used a product called PLASTIX.Its a powder that put in place and then use an aplicator to apply a liquid to activate it.I used it when I was making my gauge panel and it worked great.
      Oct 2007
      duramix
      Beacon Falls, Connecticut
      if it's abs plastic you could take some abs shavings and put them in a cup with some acetone. it'll turn into a goop, then paint the good onto your parts. when the acetone evaporates it'll leave the hard plastic again. guys having been doing this to make factory looking carputers for a while now.
      Port St. Lucie, FL
      Baking soda and superglue.
      Gary Armstrong
      Big block Duster in progress.....I mean purgatory....Hell with it I named it "Project Purgatory"
