View Full Version : power steering fitting question.
CamaroJesse
11-03-2008, 07:49 AM
I bought the DSE power steering hose kit to go with my lee steering box and gm type 2 pump but i messed up one of the fittings. Im wondering if i can go get a -6 AN fitting or if i have to use one of these. http://detroitspeed.com/productpages/indproduct/steeringprod/prssre_fitting_prod.htm
Its the fitting that comes from the top of the pump to the box.
thanks
Jesse
silver69camaro
11-05-2008, 12:19 PM
It doesn't have to be 90*, but it does have to be a fitting to accept the common teflon-lined hose, which are rated for much higher pressures than the standard braided stuff. Most hydraulic shops should have them.
mnm99
11-05-2008, 12:24 PM
This fitting will work if you have a saginaw pump. http://store.summitracing.com/partdetail.asp?autofilter=1&part=AER%2DFBM1144&N=700+115&autoview=sku I know someone sells a 3/8 to 6AN , but I cant find it.
