    Results 1 to 5 of 5
      Bleeding Wilwood Brakes...HELP
      I am bleeding Wilwood brakes with 4 piston calipers. So there is an insde bleeder on one half of the caliper and an out side bleeder on the other half of the caliper. I have gotten a fairly firm pedal just bleeding the inside bleeder on all four corners. But I don't know when to bleed the outside bleeders?
      any help will be appreciated
      Scott
      Aug 2001
      Connecticut
      bleed the outside, you need to get the air out of the cross over tube and the outer pistons... It's been a while since I did that type, I can't remember if it was outer first then inner or inner then outer, but once the bulk of the air is out is shouldn't matter which order.
      1968 Camaro RS/SS, LS7 with Katech mods, T56 Magnum, C6Z06 Brakes
      1968 Camaro RS Convertible LS3/480hp/4L70E
      1962 Corvette 327-340hp stock
      1963 Corvette Split Window Coupe
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Whittier, CA
      you might also try tapping the caliper with a rubber mallet at different spots between bleedings to bring the air pockets to the top of the caliper. this helped me on a dual piston pbr caliper once.
      good luck
      Quote Originally Posted by TIRE FRYER
      good luck
      I did do that...thanks!!
      got the brakes all bled........car is ready to drive!!
      Henderson,NV
      You always bleed from the farthest point first. Meaning RR caliper outside bleeder, then insided bleeder. LR outside bleeder then inside bleeder...etc.
      Todd
