Results 1 to 5 of 5
10-21-2008 #1
- Join Date
- May 2008
- Posts
- 1
wilwood front caliper not centering on rotor
hi guys this is my first post so go easy on me. I have a 67 camaro came stock with drums on all corners. the problem i'm having is trying to center the front caliper over the rotor (meaning from side to side. the correct installation from wilwood has the caliper mounting bracket metal to metal on to the spindel mounting point. this leaves me no movement of the caliper inward,witch is what i need to do. when i called wilwood the tech guy said we never had that problem.he thinks my spindels are not stock. i think they are. i want to know if anyone else has ever had this problem. i'm only off a 1/16 of a inch max.i'm thinking of puting a 3mm wheel spacer between the rotor hat and the hub, if it is off in the other direction then i can shim the rotor bracket away from the spindel mounting point to center the rotor. any ideas would be a great help thanks.
