    Results 1 to 20 of 20
      Nov 2004
      Palos Hills, Il
      smooth firewall for 72 chevelle
      a member on here used to make a kit to fill the firewall on 68-72 chevelles. I was hoping someone had his contact info because I lost his email with it. here is a link to his msn page http://groups.msn.com/Project60K69SS...g/shoebox.msnw
      please let me know if you know how to get ahold of him or someone else that makes a kit like that.
      Joe
      Dec 2002
      MusicCity
      New Product from MetalWorks
      Metal Works Performance engineering has this now available - click here: Firewall Smooth Kit
      There IS a difference - Thank you for choosing Hydratech!
      Paul M. Clark
      Founder / Master Engineer
      Hydratech Braking Systems ®
      www.hydratechbraking.com
      Jun 2004
      Las Vegas
      Yep, I ordered it yesterday! Call and ask for Kip or Clori..great people to deal with.
      -Keith
      zefhix
      There is nothing more common than unsuccessful men with talent-
      Nov 2004
      Palos Hills, Il
      exactly what I was looking for, thanks guys
      Jun 2004
      Las Vegas
      Careful, though...if your bondo doesn't get a hairline crack from all your torque you're going to have to leave this site
      I couldn't resist...this is usually the part where my mouth gets me in trouble
      -Keith
      zefhix
      Metro Detroit
      zefhix
      Why not just smooth out the existing firewall? I ask because I'm in the process of having this done within the next few weeks. R.P.
      Colorado
      RE: Firewall Kit
      Roger,
      The benefits that you will gain by adding a Smooth Kit will add much more rigidity to the firewall structure. As you begin the process you will imeadiatly notice that the factory firewall is very thin metal and and full of small dimples that would require a lot of spot welding and grinding, (watch out for warpage) followed by a considerable amount of filler which tends to crack from heat and the small amount of flexing the body goes through when you drive your car hard. Another benifit that you gain is a much more solid structure in which to mount the larger Air/Heating units that are required to heat and cool the inside of cars our size. The kit will also give you a more solid surface in which to pass front frame struts through that tie into a roll cage if you decide to go that way.
      Project Black Messiah
      Mike
      [email protected]
      Jul 2004
      Braselton, Ga.
      I don't know what to say!!!!!!
      that is beautiful!!!!
      i an curious, do you weld this on top of original or cut it out? And how much is this kit?
      Brent
      smooth firewall kit 68-72 A-Body
      Quote Originally Posted by Hacker Joe
      Joe
      Hacker Joe,
      We didn't forget about you. Call you on Tuesday 03/01/05
      Kip
      MWPE
      New Product from MWPE
      Quote Originally Posted by Hydratech
      Thanks Paul
      Kip
      MWPE
      68-72 A-Body firewall smooth kit
      Quote Originally Posted by Zefhix
      Keith,
      Thanks for your order.
      Kip
      MWPE
      68-72 A-body firewall smooth kit
      Quote Originally Posted by Roger Poirier
      zefhix
      Roger,
      There is quite a bit of pre-stress already built into these panels from the factory stamping and body assembly. Kind of like a soda can when you squeeze it. "Tin can" , "oil can" or whatever you would like to call it.
      This energy is just waiting to be released. Some good preparation is needed to correctly relieve and relax this stress so the panels can be smoothed.
      F1 Speed is correct on the existing firewall. If you take a look at the pictures he posted, from there you can get an idea on how much filler would be needed to fill all of the imperfections if you did not use the smooth panels.
      There are quite a few areas that will not allow you to gain enough access to properly work out the material as needed. Hence the use of the panels to eliminate this costly extra work.
      I hope this answers your questions, if not please give us a call and we will be glad to answer any questions you might have.
      Kip
      MWPE
      "I don't know what to say!"
      Quote Originally Posted by protouring70
      Brent
      Brent,
      Thanks for the cool thumbs up on the firewall panels. There is some minor cutting, stress relieving and prep work involved before the installation of the panels. But just like any other aspect of body work it is to be expected.
      Yes! For the most part the panels do get welded over the top of the existing firewall. But... If you are looking to completely cut out the existing firewall and add a whole new panel across the face, then you would be opening a completely different bag of snakes.
      I hope this information helps. Please give us a buzz and we will be glad to answer almost any question you might have. jk
      Kip
      MWPE
      303-980-4700
      Jul 2007
      Wake Forest North Carolina
      Satisfied Customer
      I just finished with the Kit and was happy. Saved me time and money. Kit makes it easy .. didn't have to think much. I started to smooth the original firewall without welding in new sheet metal ... way to much filler was required. Order kit .. easy install (and I suck at welding - novice). Kip and Metal works have continued to try and answer all of my beginner questions. It will end up looking like a professional job. Thanks!
      Feb 2007
      San Antonio,Tx
      Firewall kits
      Do they have these in stock? I assume they would fit my 72 Monte Carlo....
      Racie,
      Yes, the kits are in stock and ready to ship. They will also fit your 72 Monte Carlo.
      Please give us a call if you have any questions or would like to place an order.
      Thanks for you interest.
      Chris Lindsay
      MWPE
      Jul 2007
      Customer Example - Metalworks
      Kip (www.metalworksperformance.com) spent some time with me on the phone walking me through this and other aspects so I have to give very positive product experience .. things are turning out great with the firewall kit. I'ts my first try at this so I feel pretty happy things are looking as good as they are ... just to help I've included a before picture - and then a picture of the kit now 90% done I'm working out some small details on it and prepping the whole car for paint.... I'll post a final shot after paint. Oh - just to confirm something that has been said --- firewall is MUCH stronger now - and I only had to use finizing glaze to get it to the point below.
      http://www.lateral-g.net/members/harrod/
      May 2006
      Deerfield, IL
      Very old thread, looking to do this to my 70 chevelle, this kit still out there, the website looks to be down.
      Mt.Pleasant Pa.
      Quote Originally Posted by strtcar View Post
      look at this site.
      http://abcperformance.net/firewall%2...%20panels.html
      71 olds cutlass supreme convertible
      07 dodge ram
      96 monte carlo
      11 dodge challenger
      http://www.fquick.com/724TIM
      http://s297.photobucket.com/albums/mm206/724tim/
      May 2006
      Deerfield, IL
      724, perfect, thanks.
