    Results 1 to 3 of 3
    Thread: Will It Work?
      Jonesboro, Arkansas
      Will It Work?
      Will the stock wheels off of a '08 Corvette, work on a '68 Camaro without any kind of adapter? If you have to have an adapter what's different, the bolt circle maybe?
      Definitely won't work. They would go inboard past even a mini-tub and sit 4 or 5" inside the wheelwell unless you widened your rearend a lot because the offset is positive and you need it to be negative. In other words, your mounting surface needs to be about 4.5" inboard when measured from the backside of the rim, aka backspace but the Corvette wheel is about 8" in from the back.
      18s and 19s look great on 1st gens but the inner measurements are all wrong on the C6 wheels.
      Jason
      California
      On my 69 I use c6 wheels 18" and 19" for rollers. To make it work as a roller I had to use 3" spacers on the rear.The front works for what I'm doing but I would think a spacer would be needed also.
      1968 Camaro - Hotchkis TVS & tubular A-arms
      1969 Camaro - Project on hold
      Used to be known as sscandore
