View Full Version : LS1 head porting
The_Humbler
09-18-2008, 03:38 PM
Can 853's be made to accept 1.61 exhaust valves?
Also, are the Z06 valves the same length, or can they be made to work on a "standard" LS1 type head?
Fast01
09-20-2008, 08:42 PM
I don't believe the 853's will accept a 1.61" valve, the seats are not big enough. The LS6 valves from the 243 heads are longer (can't remember by how much) than the 853/241 valves to compensate for the smaller base circle cam used in the LS6 engine. GM decided to go that route instead of altering pushrod length.
Shawn MacAnanny
09-21-2008, 04:27 PM
I wouldnt use the z06 sodium filled valves with an aftermarket camshaft anyway as their 'hollow' stems were not really designed for aftermarket valve springs and i have read several horror stories of them breaking.
