View Full Version : Composite Headlights for 69 Camaro
skeeters65
09-15-2008, 11:46 AM
Where can I get replacement headlights for my 69 Camaro that use newer bulbs like an H4 or somthing??
Also will need the plugs for them..
Oh yeah.. I saw the DSE lights but was looking for somthing a little cheaper. Unless you think they are worth the money..
dipren443
09-16-2008, 05:13 AM
Ask and you shall receive. Both ECE (European code) and DOT approved versions are available.
http://www.rallylights.com/hella/7in.asp
Also, go ahead and relay them while you are upgrading. It will make a HUGE difference.
http://www.danielsternlighting.com/tech/relays/relays.html
skeeters65
09-16-2008, 07:43 AM
Has anyone used the HELLA lights??
Do they fit the factory headlight buckets OK??
dipren443
09-16-2008, 11:24 AM
I can't say I have used these, but they are supposed to be a direct replacement for a 7" sealed beam. I have used other Hella products and they are top notch.
marolf101x
09-16-2008, 11:44 AM
Our Velocity Camaro and the 2009 Goodguys SuperNova both use the 7" replacements from Rally Lights. The are made from real glass (no plastic here), fit perfect and work oh-so-nice. I run both the hi and low circuits off relays so as to not overload the AAW harness.
They are MUCH brighter than stock, but don't require all the extra bits that HID requires.
I'll be using them on every project we do unless I find something better.
-Britt-
Product Development Manager
Air Ride Technologies
dipren443
09-16-2008, 12:01 PM
-Britt-
Britt,
Are you using the E Codes or the Vision Plus DOT lights?
Nick
7t3 TA
09-20-2008, 05:49 PM
Britt - what wattage did you go with?
skeeters65
09-21-2008, 08:39 AM
He used the lower wattage..
I just ordered the higher wattage setup..
The guy I talked to on the phone was very nice and informative. You need to use relays for the higher wattage but the housing will be fine with the extra heat..
I am putting a new harness in the whole car so that isnt a problem..
Taylor1969
09-25-2008, 05:28 AM
Which part number for these lights is everyone ordering? There are a lot of choices on their page.
skeeters65
09-25-2008, 01:56 PM
H6024N
Is what I ordered..
High wattage NON DOT approved..
Those are Hella's best bulbs..
