View Full Version : Air Ride Kits
bigbubba
08-26-2008, 06:30 PM
Does anybody know where a good place is to buy a air suspension kit???:help!:
justanova
08-26-2008, 07:13 PM
direct at http://www.ridetech.com/
or http://www.gpsuperstore.com/forum/showthread.php?t=306
darren@ridetech
08-27-2008, 07:36 AM
What kind of car are you working on?
bigbubba
08-27-2008, 02:35 PM
Well It is a 1959 Rambler wagon with a tube chassis, mustang ll front end, and a ladder bar setup in the rear???
darren@ridetech
08-28-2008, 06:02 AM
Whose front end is it? Does it have a stud mount on top or eye? Is the lower arm setup for a coil spring or coilover? Is the rear already setup for coilovers?
bigbubba
08-28-2008, 02:43 PM
Its a stock frontend out of a 1978 mustang? Yes the rear is setup for coilovers.
darren@ridetech
08-29-2008, 07:50 AM
I are wanting to swap to tubular arms or use the OEM arms? I would recommend at least using a tubular lower so you can use the Shockwaves. They will not work with the factory lower.
Shockwaves should be an easy swap for the rear coilovers. Just give us a measurement from eye to eye at ride height. How much does the rear of the car weigh?
bigbubba
09-01-2008, 01:34 PM
I think i'm just going to run the stock lower a arms for now. I could not tell you how much the rear of the car weighs i have never weighed it.
