    Results 1 to 8 of 8
      europe
      wilwood caliper help needed
      trying to get the last of my plumbing done, and am having problems getting the lines to the calipers...the problem is that the calipers have a 1/8-27 npt thread. i can not find anyplace that sells a banjo bolt to fit these calipers. i have all new brake lines, and have the SS braided lines going to the calipers with no way to attach them .
      what are you guys using with the wilwood calipers? i am at a loss, and can't seem to figure out where to go from here...any and all help would be great. thanks.
      Jeff J. aka JJ
      1969 Camaro
      1952 Chevy Truck
      wir müssen Leben bis wir Sterben...
      Jul 2008
      Apopka, Fl.
      Jeff
      I usually go from the caliper with a 1/8 pipe to a male -3 a/n fitting and connect it to my hard line using the appropriate steel braided line for the connection.
      Bob Alford
      Pro Street Customs Inc.
      407-291-3331
      Quote Originally Posted by Bob Alford
      Jeff
      that's exactly what I did on my Wilwood's... 1/8 to -3AN 90* male to male
      europe
      so if i do that i won't be using a banjo bolt on the front calipers...right? then all i would need to do is get a ss line to go from the hardline to the 3an fitting. i understand how the back lines would connect, am i understanding right that the fronts would be the same? thanks for the help guys...
      Jeff J. aka JJ
      1969 Camaro
      1952 Chevy Truck
      europe
      would it work for the fronts if i used these parts together, and be able to still use my front ss lines?
      http://store.summitracing.com/partde...5&autoview=sku
      Jeff J. aka JJ
      1969 Camaro
      1952 Chevy Truck
      Jun 2006
      Katy,TX
      Wilwood calipers even the GM styles do not use a banjo- they use a 1/8 pipe fitting. So you will have to convert the lines to a AN style or hard line using a 1/8 to a inverted flare.
      Aug 2003
      Orlando, FL
      Exactly why we provide the lines and all the bits with our kits.
      Hopefully we got you squared away yesterday Jeff. Next time you will buy your brakes from us, LOL!
      Sorry, could not help myself.
      europe
      Thanks much Frank. Got the parts ordered yesterday and should have them by friday. had i known about you guys when i ordered, i would have ordered the kit through you guys and have it all together already . lesson learned...thanks again
      Jeff J. aka JJ
      1969 Camaro
      1952 Chevy Truck
