    Results 1 to 4 of 4
      Country Flag: China
      Need Help - Will Baer Disc Brakes Work With C-Clip Eliminators?
      Will Baer disc brakes work with c-clip eliminators? Specifics below.
      1968 camaro with 12-bolt rear, GM axles and c-clip eliminators
      Baer Sport rear disc brake kit for 68-69 F-Body P/N 4302051
      If so, how does the caliper bracket mount? Inbetween the flange on rear end and c-clip eliminator? Any issues with this setup (sealing, axle stand off length, etc.)?
      Did a search and can't figure this one out. I will be calling Baer tech support on Monday. Baer website not so helpful.
      Fontana, CA
      Normally c-clip eliminator axle ends are Ford style and would therefore require a ford specific rear brake kit, at least for the caliper brackets.
      Nick R.
      Jun 2006
      Katy,TX
      A buddy with a 79 TA used the factory disc with C clip eliminators from Moser. Moser wasn't sure they would work but he said no problems at all.
      Be sure they know what brake pattern ie GM for a GM whether you are using disc or drum.
      Country Flag: China
      Thanks for the info. They are Moser c-clip eliminators and my current brackets for the disc brakes are for 67-69 F-body GM.
