View Full Version : Clutch safety switch
Jim Nilsen
08-17-2008, 08:36 AM
I am looking for a switch to install on the pedal assembly of my 67 Camaro so that the car won't start unless the clutch is disengaged. I have tried a brake pedal switch but it will activate before the clutch is fully released. I just tried to use one of the brake light switches that has the adjustable levers but it will take some really elaborate bracketry to install it.
Does anyone know of a stock switch that would be easier to install and work like I intend it to?
What switch did you use?
parsonsj
08-17-2008, 09:36 AM
Jim,
Have you considered a neutral safety switch? That's easier to do, and just as safe.
jp
Jim Nilsen
08-17-2008, 07:07 PM
Jim,
jp
Hi John, I have considered it and it may be an alternate way to do it. I can use a lever type micro switch to do it with the clutch if needed but I am hoping that someone will have a simple stock switch that is less expensive and still easy to mount.
I never even had one for 10 yrs and if you forgot you knew right away:jawdrop: . When my bellcrank stud broke once I was able to put the car in 1st and turn the key and the car would start and imediatley take off even on a hill. I would then just power shift the car to get home and just take it out of gear to be able to stop.
I might just go with another brake light switch and it will keep it from starting if you don't depress the clutch at least an inch and I would still be able to get home like I did when the stud broke.
Why is it the little stuff like this can be the biggest pain to get installed.
:cheers:
parsonsj
08-17-2008, 07:43 PM
My story without a neutral safety switch was when I went to start the car with the back tires on wheel dollies...
The dollies shot out of the back of the car and the car dropped 4 inches to the ground. Scared the crap out of me! I stopped what I was doing, disconnected the battery, and immediately installed a neutral safety switch.
jp
Larry Callahan
08-17-2008, 07:46 PM
I am also trying to figure out how to do this. My Richmond 6 speed does not have a built in switch. Somebody must have figured out an easy way to do it.
Vegas69
08-17-2008, 07:52 PM
My beamer has got me in a habit of starting with my foot on the brake. My chopper also has no safety switch. It's a good idea but I don't have it on my car. I didn't trust the TKO 600 switch to carry the load of the system.
parsonsj
08-17-2008, 08:03 PM
I didn't trust the TKO 600 switch to carry the load of the system.You shouldn't. The TKO switch should only power (or ground) a relay that carries the current to the starter.
jp
all wired
08-17-2008, 09:48 PM
although not optimal, you can connect that brake switch you have to your clutch assembly, then use a relay so that your foot has to be on the brake pedal (and the clutch) to start....
Bow Tie 67
08-18-2008, 05:47 AM
Fourth gen cars use a Clutch pedal safety switch that is actuated ( depressed ) when the upper portion of the clutch pedal arm contacts it. ( the clutch has to be fully depressed ) This completes the circuit for the starter relays coil. The contact side of the starter relay then completes the ignition switch to starter coil circuit.
Jim Nilsen
08-18-2008, 06:11 AM
Sounds like what we are looking for. Are you able to get a pic of how it is mounted ?
Bow Tie 67
08-18-2008, 07:57 AM
I will write myself a note ( old age ) and try to get a pic tonight. After hearing some of the stories I need to address this on mine.
Motown 454
08-18-2008, 01:42 PM
Check out American Auto wire they should have exactly what you want My 69 Z28 had one from the factory.
DarkoNova
08-18-2008, 02:28 PM
Didn't manual cars have this from the factory? My car was an auto, so when I conveted it to manual I didn't worry about the neutral safety switch. I always leave the car in neutral anyway, so I've never had the scary experience of almost plowing through something in front of the car, lol.
Matt
Bow Tie 67
08-20-2008, 02:33 AM
Here is the switch dead center in the pic, the clutch arm is at the top of the image.
https://static1.pt-content.com/images/pt/2008/08/IMG_0013-1.jpg
Here is the switch depressed with the clutch pedal depressed. There is a bracket on the pedal arm that depresses it. Both views are with the camera pointing straight up from the floor.
https://static1.pt-content.com/images/pt/2008/08/IMG_0012-1.jpg
Jim Nilsen
08-21-2008, 05:17 AM
Thanks for the pics, it's a little hard to see it but I finally caught it and it looks like it won't be that expensive. Now it's time to call for the part number and the price.
jjump59
08-21-2008, 06:31 AM
my 70 GTO has a small cylinder type switch with a bracket attached. sorry no pics but i'll bet it would work very well.
Overkill
08-21-2008, 06:55 AM
I used a micro switch like they send with nitrous kits.
https://static1.pt-content.com/images/pt/2008/08/camaro_rebuild484-1.jpg
67camaro972
08-21-2008, 04:10 PM
i used a generic brake switch for my car, 67 camaro, fab'd in a piece of metal and bent it over at a angle... drilled a hole in it, size of the switch... and welded it right next to the factory brake switch... so in essence i have 2 switches under the dash now.. one for the brake pedal.. one for the clutch pedal.. for the new switch, clutch pedal... i wired in a relay figuring that the amp draw on the starter solenoid/ purple wires be to much for the switch... to start the car now the clutch must be depressed. i also have a t-56 in the car... if u wire up the reverse lockout off the brake pedal switch.. be careful... when u hit the hazzards the reverse lockout will be going on and off a million times with every flash of the hazzards. I thought about using the new switch.. off the clutch to actuacte the reverse lockout.. after a lil thinking and sobering up, that would be a idiot move...got to press the clutch in anyways to make the bone head move of throwing it in reverse while moving forward.....
Jim Nilsen
08-23-2008, 03:19 AM
That's pretty nifty too. How much do those switches cost?
Does it bend the rod a ways before it activates or is it touchy?
Thanks for the good pic.
Bow Tie 67
08-23-2008, 05:24 AM
I like that idea better also. We use them on aircraft, I dont know the cost but you can bend the tab to adjust the actuation point.
Overkill
08-25-2008, 04:38 AM
It's been a while since I bought and installed the switch, so I don't remember what I paid for sure. I did a search on Jeg's and it looks like a microswitch with a universal bracket run in the neighborhood of $15.
It isn't really that touchy. There is some play before the switch actually activates and of course you can adjust the bracket to a position that you want it to be for activation. From what I could see, the rod only bends just a little after the switch activates. In the picture it is showing with the pedal depressed and you can see that the rod is only bent a little bit.
