View Full Version : getting new toy/project
joe5.8
08-15-2008, 03:18 PM
some stuff the car has with pic's
SRP Flat Top pistons
Scat I beam rods
Stock Polished Crank
AFR 185 cc heads 58cc combustion chambers
Crane Gold Roller rockers
TFS Push Rods
Holley Systemax II intake
Custom Comp Cams Hydraulic Roller Cam
Mac 1 3/4 ceramic coated long tube headers
3" H Pipe, 3" flowmasters, 3" tail pipes
BBK 70mm throttle body and EGR spacer
42 lbs injectors
Aeromotive fule regulator
PMAS 80mm Mass air
AFM PMS, Series 4
Vortech V2 supercharger 2.95 blower pulley 6.87 crank pulley, 10 rib
AFM power pipe
Snow performance methanol injection
Holley 2551ph fuel pump
T Rex in line fuel pump
Fluidyne radiator
Edelbrock high volume water pump
Summit SFI balancer
Taurus 2 speed electric fan
Tremec TKO 500
Centerforce dual friction clutch
FRPP aluminum drive shaft
3.73 gears
Tubular frame connectors
UPR rear upper and lower control arms
Rear coil overs w/ lakewood shocks
UPR Tubular K member w/ A ar,s and coil overs
KYB struts
Maximum motorsports caster camber plates
UPR bump steer kit
SN95 front brakes
FR500 wheels 17X9, 17X10.5
MT et street radials
Moser 35 spline axles, c-clip eliminators & spool
Aerospace Rear Prostreet disc brakes
Cobra Master Cyclinder
Rollbar - Powder coated to match interior
Impact 5 - Point Belts
Battery relocated to trunk - master disconnect switch installed
joe5.8
08-15-2008, 03:21 PM
93 mustang coupe
progoat
08-15-2008, 04:02 PM
I'm not a ford guy but for some reason I like the notch backs...haha
TPI Monte SS
08-15-2008, 06:10 PM
Very nice! Even though I'm a Chevy guy, that's exactly how I've dreamed of building a notchback Stang. Very subtle, and very cool. Good luck with it!
jerome
08-15-2008, 07:24 PM
I don't know why, but I love notchbacks too...another chevy guy here
There's another red one on here that is on air ride, slammed...they look so sexy dropped
