Results 1 to 5 of 5
Thread: Installing a 700r4
08-13-2008 #1
Installing a 700r4
Im getting ready to mate my 700r4 to my 350. The converter has some ATF in it already should I dump it and put fresh oil if so how much oil?
1970 TA, 1963 Impala SS vert
09-01-2008 #2
- Join Date
- Aug 2004
- Location
- England
- Posts
- 1,042
You might have fitted it but yes you should, you will only fill it up half way as it will come back out when setting it in the engine, also the oil coming out you can see what the old oils like.
09-01-2008 #3
- Join Date
- Aug 2004
- Location
- England
- Posts
- 1,042
actual what yr is it as some early 1s could not handle the power,as i found out :( .
09-03-2008 #4
- Join Date
- Aug 2004
- Location
- England
- Posts
- 1,042
Just had this months popular hot rodding ,and it say it;s a def no no installing it without oil.
09-03-2008 #5If the fluid in there is good then leave it. If you are not sure then drain it.
You aren't going to get all of it out no matter what you do.
Add a few quarts to the converter, then tip it upright and see how far the fluid drains into it. You want to fill it as far as it can, but when you install it on the trans some of the fluid will drain if you add too much.
