    Results 1 to 5 of 5
      Jan 2007
      Port Orchard, WA
      BS translation from mm to inches.
      What is the backspacing in inches, 35 mm and 45 mm?
      Snohomish,Wa.
      45 mm is equal to about 1.77 inches. 35 mm is equal to about 1.38 inches. That almost sounds like offset, instead of backspace?
      Roger
      Jun 2008
      Lenie, I responded on the other site. Need to know your wheel width - you are supplying offset (is that negative or positive?).
      See the attached chart for some close estimated depending on wheel width.
      1970 Dodge Charger - Viper V10/6spd
      Mountain Springs, Texas
      Here's a great calculator:
      http://www.rims-n-tires.com/info_specs
      Don
      Jan 2007
      Port Orchard, WA
      35mm (8 1/2") 45mm (9 1/2"). Thanks for the help.
