View Full Version : 67 10 bolt on a 71 chevelle
1badchevelle
08-08-2008, 09:42 AM
Can I use a 67 chevelle 10 bolt on a 71 chevelle? what would be the down side? 12 bolt are high $$$ if you come across a good one. I can just build up the 67 10 bolt. THis is a daily driver and will be in back of a ls1 motor.
Thanx
rob07002
08-08-2008, 09:48 AM
If its an 8.2 10 bolt, its not really worth putting any $$ and time into it. I'd look for an 8.5.
gearheads78
08-08-2008, 10:04 AM
Find an 8.5 out of a 71/72 BOP car. It will bolt in and hold decent power or can be built up as strong as a 12bolt. The axle tubes to center housing will be a weak link under a lot of power. You will want them welded by someone with a jig that knows what they are doing to make sure its still straight.
zman1969
08-12-2008, 08:58 AM
the 8.5" you want only came in '71 '72 Skylarks and Cutlass! pontiacs had their 8.2" -posi's are plentiful and gears too and they have bolt in axles so no worry about C-clips breaking and losing an axle these rears will run you into the 10's W/O breaking too.
bochnak
08-12-2008, 12:05 PM
That rear end is about 2" narrower? It also uses a different spring perch.
http://www.chevelles.com/forums/showthread.php?t=228088&highlight=rear+end+width
Randy67
08-13-2008, 04:33 AM
The rear end is narrower but the spring perch is the same, only 64-66 models had the different spring perch.
